gimpyrobb
dumpsterlandingfromorbit!
- 27,791
- 787
- Cincy Ohio
Well, the plan was to pull the intake and exhaust to see what was going on. We pulled the intake horn and I couldn't spin the blades by hand. I had him start it up and the blades were not moving. Once pulled, we could spin the blades(go figure). Also the V band clamp that holds the exhaust snail shell to the center section had its T-bolt broken, so I'm sure exhaust was escaping. Finally, there was a lot of black oil on the compressor side, I believe to be crankcase oil.
All in all, I think it was just worn out and needs a rebuild. There was no play in the shaft though, so I don't believe its trashed.
