TwistedOaks
9
Odessa, Florida
Started my big changeover to the M915 Battery box. Had to work out exactly the right distance to offset from the frame so the step would fall under the door correctly, without having the bottom step stick too far past the body. 3.5" was the magic number. 3.5" just happens to be the short edge of the only piece of stout steel I had laying around (7/16" angle 3.5 x 5). Had to move the exhaust bracket over a little. Next is removing the current battery box (toolbox) and mounting the new MRAP air tanks, then remounting the tool box, which will finally be used for tools!
Am really happy with how solid it feels. We'll see if I still feel that way after 200lbs of battery get loaded in, then jump on that step with my 280lbs.
fuzzytoaster
3,707
Fort Worth, Texas
View attachment 666304View attachment 666305View attachment 666306
I'm literally in the middle of doing this upgrade. Do share pics of the tanks, location, etc! Good work!
Swamp Donkey
The Engineer
126
Gray, GA
I finished making my overhead console. Just have to do the final paint and wire up the lights. The hole in the last picture, to the far right, is for the 4 channel camera monitor.
Swamp Donkey
The Engineer
126
Gray, GA
That's an excellent build-out, Swamp Donkey.
Did you fabricate all the pieces; and how did you make the radius cuts on the sheetmetal corners, a grinder?
The bottom is actually an old sign, hence the rounded corners. It happened to be the perfect length and width that I wanted. Since it's aluminum, holes are easily drilled for new additions without removing the whole console from the truck. I made everything else.
MCSFBN
Here in Angleton, TX
Ordered up some new gear for my 925.
Have in hand:
Locking gas cap
Locking door handles
Keyed ignition
24 to 12 V inverter
XL RAM air intake
New brighter headlamps
red LEDs for "tactical" interior lighting
white LEDs for "not so tactical" interior lighting
2x2" LEDs for rear external work lights
2x2" & 1x32" LEDs for forward takedown lighting
6 switch custom rocker panel to wire it all in
Waiting for them to arrive:
New GI anglehead flashlight for toolbox
New heavy canvas "US" stamped tool bag
New green 5gal/20ltr water can
Most came from TMG the rest from various places on the interwebs
Just gotta get busy
simp5782
Feo, Fuerte y Formal
9,509
Mason, TN
Met up with the gimpy one and we got all of G's stuff loaded bound for eastern north Carolina. 5 ton rollin .IMG-20170215-WA0001.jpgIMG-20170215-WA0005.jpg
Sent from my SM-G860P using Tapatalk
gringeltaube
Staff Member
2,690
Montevideo/Uruguay
............. There is all kinds of room left in that container, not to mention your empty truck bed.
There simply wasn't more junk of mine left there, to fill that box up to the roof. Still, it is heavy enough already, as it is - for a long-distance, 10h-ride to follow.
And yes, there was enough other heavy stuff going in the bed.
Those trailer ramps are looking pretty sad.
Not sad, just funny...! Called "semi-elliptical, load-tested ramps"...:mrgreen:
simp5782
9,509
Mason, TN
Come on Wes
My truck bed has two 16.00s. Two 9.00s. And a 14.00. A engine in a crate. Hmmwv doors and other assorted junk.
I am sitting at 55,780 gross.
Everyone picks on my ramps but until they can't hold anymore ill use em. They held that 35,000lb mini ex the other day.
fuzzytoaster
3,707
Fort Worth, Texas
I got my battery box on yesterday and relocated the 2nd air tank to inside the frame. In fact it could almost pass as stock! Now I just want to put something in the "gap" above the battery box to flesh out the area some.
Ford Mechanic
10
Edenton, NC
Hey where at in eastern NC are you moving to? We live in eastern NC maybe your close.
Sent from my SM-G900V using Tapatalk
