- 1,517
- 1,182
- TN
I replaced the air suspension on my M1088. It rides SO much better now. Notice how ballooned the old one was. The leading edge of the rubber shocks on mine were dry rotted. Checking your shock is easy and does not require removal. Just take a mirror and look at the rubber at the bottom. The shock should balloon and fill the cylinder. If it does not, you likely have a baView attachment PP938900-2G.pdf
Here are picts from the rebuild. I did not have a delay in shipping. They were in stock. I talked to Tech Support. Very Helpful. Sounded like they are aware of the need for replacement parts for military trucks and are addressing it. Mine DID NOT have O rings in the bore, so I had to buy some. Suspension rides about 3 inches higher now. Anyone know where I can get a new black rubber bushing to replace the one in the picture?
Qty Name SKU Each Subtotal
2 PP997900 POWER PACKER $189.00 $378.00
Subtotal $378.00
Shipping: UPS Ground $26.45
Tax Total $0.00
Grand Total $404.45
Order from Ohio Hydraulic
