M1088 Cab Air Suspension rebuilt-wow, what a difference!
Reworked LMTV
1,541
1,203
TN
I replaced the air suspension on my M1088. It rides SO much better now. Notice how ballooned the old one was. The leading edge of the rubber shocks on mine were dry rotted. Checking your shock is easy and does not require removal. Just take a mirror and look at the rubber at the bottom. The shock should balloon and fill the cylinder. If it does not, you likely have a baView attachment PP938900-2G.pdfIMG_1110.jpgIMG_1109.jpgd shock or O ring or both.
Here are picts from the rebuild. I did not have a delay in shipping. They were in stock. I talked to Tech Support. Very Helpful. Sounded like they are aware of the need for replacement parts for military trucks and are addressing it. Mine DID NOT have O rings in the bore, so I had to buy some. Suspension rides about 3 inches higher now. Anyone know where I can get a new black rubber bushing to replace the one in the picture?
Qty Name SKU Each Subtotal
2 PP997900 POWER PACKER $189.00 $378.00
Subtotal $378.00
Shipping: UPS Ground $26.45
Tax Total $0.00
Grand Total $404.45
Order from Ohio Hydraulic
coachgeo
3,482
North of Cincy OH
Did you replace with whole new shock and bag from Power Packer as a new unit or did you rebuild them from parts via Power Packer. Either way.. your cost ended up around?? and what all did that cover?
lesrrt
Cecil county, MD
The bushing you are referring, looks similar to a Mercedes top cap rubber bushing they use on top of coil springs. Does Caterpillar show that on their parts schematic? Depending on the diameter, I have seen fellas make lift pucs from old hockey pucs.
Reworked LMTV
1,541
1,203
TN
$400. You reuse the portion inside that looks like a typical shock absorber.
Reworked LMTV
1,541
1,203
TN
Not sure CAT made these. Maybe I should contact Stewart & Stevenson. Hockey puck? Not a bad idea : )
snowtrac nome
140
western alaska
after years of driving 1 tons around this area I do love the air ride on my cab with the conditions being what they are this may be something I will have do in the future
TNriverjet
24
Clifton, TN
$400 total is much better than $375/ea for the NOS cab air ride units on the big auction site. I will definitely keep this in mind if I ever face failing air ride!
yertnamreg
21
Houston TX
Just noticed a leak on one of mine and wanted to ask a quick question before I order parts.
In one of the part spreadsheets going around there is a mention of an "Airbag Sleeve" P/N (Firestone
W02-358-7074), which is much cheaper. It looks suspiciously similar to the PP part. Does anyone have any thoughts on what it would take to repair the system using just this part instead of the whole assembly?
Thanks!
agazza2
35
Ahwatukee, AZ
I ordered one of those for $40. But unless you have a way to buy and crimp on a new band at the top and bottom, this cannot be done. I ended up paying the $200 for the proper assembly and it was the best choice in my opinion. If you want to try the cheaper option, I will sell you mine for less than i paid for it as it has been just sitting on a shelf for the last month.
agazza2
35
Ahwatukee, AZ
That is correct, if you search my posts for FMTV upgrades and repairs I have photos. Plan on replacing the upper bushing as it will most likely be rotted out or missing.
coachgeo
3,482
North of Cincy OH
did you try a good ol big hose clamp?
