hmmwv tow bar
DatGuyC
20
Essex, Maryland
Informative thread even for those who are sans HMWWV. My question from the outside looking in, are the HMMWV tow shackle anchors available? They look somehwat useful on another project I have.
part number 12342404, like the other guy said much more expensive at about $50 each if you shop around
diesel dave
north central pa
I was under the impression that flat towing a Hmmwv is a no no unless you remove both drive shafts. I read in a tm that flat towing could be done for less than 10 miles at a speed not to exceed 30 mph. It seems the previous post by 70 deuce showing the front lifted and rear drive shaft removed confirms this?
Action
1,552
East Tennessee
I, personally, do not see how flat towing works.
If the front vehicle makes a turn, wouldn't some of the Humvee tires have to slide sideways on the pavement?
ryanruck
Cincinnati, OH
Figured I'd resurrect this thread so I didn't have to start a new one...
Recently picked up one of the black Ibis Tek HMMWV towbars (for just $50! :mrgreen:) but it's missing all the rubber handled hitch pins.
Does anyone have the dimensions of both the thicker and thinner ones?
ryanruck
Cincinnati, OH
Since no one had the answer, I'll follow up with what the correct pins are in case anyone else needs the info for future reference.
The larger pins that go through the shackles are 3/4"x4" and the smaller ones that go through the legs are 3/8"x4".
