Well Shes getting naked! Camper Part Deaux!
Reworked LMTV
1,168
TN
profo
72
jeanerette,la
In the truck there are three layers of 1/2 foam board on walls and roof and floor is sprayed with two layers of gator skin sound damping then two layers of gator skin heat shield then one layer of simmons industries olive drab rubber spray. I also removed the r134 and put r12 in the AC unit and it cools great and is about as quiet as my dodge ram truck inside, all you hear is the whine of turbo, I also have the high speed gears so at about 60 shes only turning about 2k!
profo
72
jeanerette,la
A lil more work done if everything goes good the camper section should be painted this weekend and the homeade generator should be done also.generator box.jpggenerator.jpgshes primed.jpg
