Ok so here is a thread I am going to do on installing a DP Hydraulics winch into the rear of my truck. This will take me about 2 weeks or so. Hopefully no more BUT we all know how Wile E Coyote projects go.
Unit arrived today from Cleveland, TN. It was advertised as a 50,000lbs DP winch. Showing up it is a 60,000lb model. Old enough that they don't list it on their site for it's specs. So I fired off an email with the model and serial number to see what they can tell me about it.
Overall Dimensions Width: 48" including mounting base. Winch itself is 41" wide.
Front to rear depth : 24"
Height : 26"
Weight : 1,375lbs
It is pretty big looking in the back of the F-250. Cable is rusty and doesn't have much on the spool so I will probably go down smaller and add a little extra length.
Hopefully I will have all the specs on the winch tomorrow.
My plans are to run the winch off an aux gas engine. Probably a 25hp V twin and its own pump and tank. Maybe a future front winch but not as big but easier to hook into the same system.
May get to setting it in the back tomorrow and find a potential mounting setup. My plans are going to be to cut the bed out right around the frame and add braces for the rear of the bed to go the ouside of the frame. Remove part of the risers the bed sits on. Use a 3/4" plate that I have and mount it to the frame and also with 2" x 3" 3/8 angle iron mounted to the frame (same way the 5th wheel plate it mounted to the tractors.) Winch sill be bolted to the 3/4" plate accordingly. Probably by five or six 5/8" bolts on the front and on rear of the cross mount. It will sit a little high in the bed but the tailgate will hide it. It will sit with the fairlead up against the tailgate.
The pump setup will be gone thru when I get it all together. I am going to be looking at a 30 to 40gpm pump.
Height : 26"
Weight : 1,375lbs
