Where did you pick up
Picked up in Lake Butler, Florida. Iron Planet rep Larry was great, very helpful.
I had a chance to look her over this morning and was very happy with what I saw. Inspection report showed head lights not working but they did, so got 2 LED headlight, batteries look recently installed, no corrosion, clean, date codes only 1 month apart manufactured in 2013 (Hawkers), engine compartment clean except for spider webs, engine looks new, just a little corrosion on bolt heads, new looking yellow tag EESS box and temp sender, went on very short test drive this morning, shifts smooth, oil looks new (very clean), transmission fluid also looks new, (yes, I am going to change both), up coming projects, check and change gear oil in hubs and differentials, I want to start with all fresh fluids and filters, install grounding kit, give her a good bath and go from there.
