I bet I have hubs.
Check Chris....I'll PU when I get the 105. Is there a Wisconsin rally and are you going? Maybe Haspin.
I bet I have hubs.
BView attachment 720630
Isuzu 16 inch wheel drum off.
Not the same... the only thing both hubs have in common is the diameter of the bore for the bearing cups.I was referring to the smaller bearing used on the deuce hub. When you "flip" the hubs all the weight is now carried by this smaller bearing. Since the hubs are the same as the M105 trailer why can't we use the larger M105 bearing there ?
... Deuce hub on a Deuce axle... (I only wrote that in response to Greg's question.)......... But is this comparison a comparison for use of the M105A2 bearing in a deuce hub on the deuce axle or the M105A2 axle?
Give me a bit more time to completely pull apart a M105 (A2) axle and then come up with full drawings/dimensions.I wish I had both of them (or even one) apart to compare and take dimensions.
Thank you very much G. Bearing placement on the axle and this swap have been debated both ways (in favor and against) and it will be great to have a definitive answer to what is required for dish out mounting (and have bearings approximately centered on the wheels).... Deuce hub on a Deuce axle... (I only wrote that in response to Greg's question.)
I agree: whatever the solution was, this is not just swapping parts.
This is the M105A1 axle?
Pics
View attachment 720765View attachment 720766View attachment 720767
Note according to Sam Winer the drums and adapters for the M105A1 (with 2 wheel cylinders per drum) are the same for the M211
