M105 axle assembly to accommodate dish-out combat wheels
drivebymashing
52
North Carolina
It's really close like less than a 1/4 inch. It fits though. I want to remove shoes wheels cylinders. I'm not sure backing plate will come off. It looks like it needs to be there.
gringeltaube
Staff Member
2,690
Montevideo/Uruguay
I was referring to the smaller bearing used on the deuce hub. When you "flip" the hubs all the weight is now carried by this smaller bearing. Since the hubs are the same as the M105 trailer why can't we use the larger M105 bearing there ?
Not the same... the only thing both hubs have in common is the diameter of the bore for the bearing cups.
The outer spindle diameter is 61,91mm for the M35, vs. 66.68mm on the M105. And the dimension "T" is 1/8" more for the 39590/39520 bearing, compared to the 392/3920. That means we could use the larger bearing there, but only if... 1) adding a sleeve on the spindle; 2) machining the M35 hub (on the flange side only), to make the bore about 1/8" deeper (otherwise there wouldn't be enough thread left, for the counter-nut); 3) creating a new oil seal...
All that for what... 25% longer life time - eventually...? I'd say, run good quality, stock size bearings there and safe time and money.
tobyS
840
IN
Okay G, Without having these in front of me or scale drawings I have to admit, the numbers get confusing. Your drawings help significantly. But is this comparison a comparison for use of the M105A2 bearing in a deuce hub on the deuce axle or the M105A2 axle?
I missed what you are pointing out by not comparing all of the dimensions. The T on 39520 and 3920 (cup width) are the same, but the bearing cone width are much wider (and different ID). I wish I had both of them (or even one) apart to compare and take dimensions.
It may be easier go back to plan 1 and machine off the wheel mount flange on the M105A2 hub and use the brake mount flange for the dish out mounting. Even if I machined off enough inside shoulder on a deuce hub so the bearing would fit and a seal go in, I don't know that the bearing placement on the axle is correct.
What seamed like an easy swap of hubs (M35 for M105A2), using the bearings for the axle (M105A2), appears to be not so easy of a swap.
gringeltaube
Staff Member
2,690
Montevideo/Uruguay
......... But is this comparison a comparison for use of the M105A2 bearing in a deuce hub on the deuce axle or the M105A2 axle?
... Deuce hub on a Deuce axle... (I only wrote that in response to Greg's question.)
Give me a bit more time to completely pull apart a M105 (A2) axle and then come up with full drawings/dimensions.
I agree: whatever the solution was, this is not just swapping parts.
tobyS
840
IN
Thank you very much G. Bearing placement on the axle and this swap have been debated both ways (in favor and against) and it will be great to have a definitive answer to what is required for dish out mounting (and have bearings approximately centered on the wheels).
gentrysgarage
118
Lost Angels, CA
Pics M135 axle
Note according to Sam Winer the drums and adapters for the M105A1 (with 2 wheel cylinders per drum) are the same for the M211
gentrysgarage
118
Lost Angels, CA
This is the M105A1 axle?
M135 axle, edited previous post. Also for clarity, I am recommending checking out the M135 (singled deuce) brake drum and adapter for the offset to be helpful to you. These are only on the rear wheels the fronts of the M135 are the same as the M211.
tobyS
840
IN
This thread popped up and I'll update a couple things. Running dish out A3 on a stock 105 puts the load entirely on the outer bearing...and wheels must be beveled for wheel nuts.
While eventually I will modify my rims for the deuce, it's too much $$ for a 105.
So...I'm going to bolster wheels, one piece 16.5 that can take a 37" hummer tire.
And just to put this up..... the 19.5" Isuzu budd wheels fit over the brakes fine and is under the legal limit. Tires are 31" dia.
