I do know there are two different cables for the two different handles, whether or not one works with the other I don't know.Another *fun* project that I get to do... Anybody know if the "twist the knob to adjust" parking brake handle is a direct swap for the older *whale tail* style? I like the thought of being able to simply adjust the cable without having to crawl under the truck.
No, you will need to swap out the cable under the truck too.Another *fun* project that I get to do... Anybody know if the "twist the knob to adjust" parking brake handle is a direct swap for the older *whale tail* style? I like the thought of being able to simply adjust the cable without having to crawl under the truck.
Once the cable is properly adjusted at the parking brake, you can adjust handle travel of the "whale tail" in the cab.Another *fun* project that I get to do... Anybody know if the "twist the knob to adjust" parking brake handle is a direct swap for the older *whale tail* style? I like the thought of being able to simply adjust the cable without having to crawl under the truck.
Could you post some pics of that additional tank and the mount?For what is worth, I swapped out the whale tail P-brake lever for the twist to adjust knob handle P-brake lever. I am happy with it, but routing the cable was a real chore, made worse due to the fact I added second 50 gallon fuel tank on the drivers side and removed the spare tire carrier and pioneer tool rack. But it does work nicely.
Gotcha, thank you. I have a tank that is a little larger than a stock tank that I have to figure out how I want to mount. You going to do a transfer pump type setup to feed other tank?View attachment 757241View attachment 757243 The tank is mounted but not connected yet, I got a really good deal on the tank and brake lever and quickly mounted/installed them to not have loose pieces laying around but moved out of California before I got everything done. The mounting is just like the original one except the filler is at the rear of the tank because it is a stock tank and mounting brackets. I just drilled holes in the frame and bolted it on like the one on the passenger side if that helps.
1" ID x 1.375". I copied what I saw on hanks deuce, I'm not gonna duplicate his whole fording set up but this was a no brainier.What size hose are you using? 1" maybe? I keep forgetting to measure the intake on the air compressor.
