I have joined the club ! And yes I have lost my mine !
1951M1078
185
Glendale,AZ
I made it 3' x 4'. 12 sqft out of 128. It could be made smaller but I like taking a real shower. The control is more how much water you have. I have 42 gal.
The other plus is the cassette toilet. No black water tank.
dougco1
695
Cooperstown NY
1951M1078
185
Glendale,AZ
Lots to do before Expo 2019. Worked on the sub-frame and bumper.
Needed to get this installed so I can workout the water a gray tank.
coachgeo
3,484
North of Cincy OH
More work on the DOT bumper. And worked out the swing for offroad storage....
Like minds!!! Look forward to see how you do your lock in place that allows you to tow with it/provide slow down of car that rear ends you just enough to avoid their decapitation. Granted that rearender is sorta earning their own a Darwin award ... but then again they are someones mom, dad, or sibling... so guess it is worth it.
1951M1078
185
Glendale,AZ
[FONT=&quot]A day of building brackets. Drilling a 1" hole takes some time.
[/FONT]
IMG_6043.jpgIMG_6044.jpgIMG_6045.jpgIMG_6046.jpgIMG_6047.jpgIMG_6048.jpgIMG_6049.jpg[FONT=&quot]
[/FONT]
[FONT=&quot]The short one's are 3/8" and the long are 3/4 (2 x 3/8"). I don't have anything over that. My bad. On the long,it will pass-through the 1/4 x 3 x 3 . Will slot the bumper and weld it in place. Will be a pull point that will end at the 1" point in the chassis. Bore to come.[/FONT]
1951M1078
185
Glendale,AZ
Tow points.
have not added the bracing yet. May not until after the show ? Too much other stuff to do.
1951M1078
185
Glendale,AZ
All welded up. But needed to pull something apart. I forgot about the lift on the back of the truck. Don't want to have a problem with the hitch !
Still need to add some bracing but that will come later.
