fpchief
- 229
- 63
- South Alabama
Not sure how much. I think I used maybe 3 pints when I re-worked my brake system. I may have had some in the airpack already. All wheel cylinders were empty and MC was empty too...That is with bleeding them good. But...if you don't have any, it may be cheaper to get the gallon from Big Mike. I hope you didn't pay too much for that bleeder. I made mine for about $10. Not fancy but absolutely does the job.Cleaned the inside of the cab, opened the plate to get access to the master cylinder,cleaned around the master cylinder before opening only to find out it was bone dry.checked prices for dot 5 brake fluid, ordered power bleeder, not sure how much break fluid will be needed. can someone tell me how much will be needed.
thanks
![20190615_192117[1].jpg 20190615_192117[1].jpg](https://www.steelsoldiers.com/data/attachments/526/526804-5d606a9f5bd319636cc3be3dc0802f52.jpg)
![20190615_132047[1].jpg 20190615_132047[1].jpg](https://www.steelsoldiers.com/data/attachments/526/526805-1362572e030dba129b11769f9833bc6d.jpg)
