need hemtt Detroit Diesel 8v92ta mechanic near Sacramento
bigmike
364
Dixon CA.
Silverstate55,
I have not checked that yet. My understanding is that the oil cooler failure would more than likely put oil in the water because of the pressure difference. The radiator fluid was green when I drained it. I'm focused on getting everything clean, get the liner clamps made, then inspect each cylinder. Once that's done, I'll be ready for a parts order. I'm holding off on ordering seal kits until I can clamp the liners down and hand-turn the motor over so I can inspect every liner. If all looks good, I'll just be ordering seals....lots of seals.
silverstate55
Unemployable
2,124
1,077
UT
Silverstate55,
Sounds good, sorry to jam your thread.
MrMikey4026
417
Eatonville Washington
If you have scuffed pistons, you will also have leaking liner seals. Better pull the liners and replace them. PS, been working in Detroit's for nearly 50 years.
Cheers
Mike
bigmike
364
Dixon CA.
Update 1/18/20:
Cranked the motor over with a big socket. Found 4 liners cracked all on the right bank at the base of the air chambers. Sucks but at least I spotted them now. Everything else is removed and ready to order parts.
davidb56
1,238
Bonners Ferry Idaho
Update 1/18/20:
Now comes the hard part.......you need to find out WHY the 4 liners cracked, before you reassemble it. My first guess would be overheating on that bank., or the wrong head gasket on that side used if someone pulled the head because of the common head gasket failer.
bigmike
364
Dixon CA.
It’s temperature...I almost positive. That is the side where the water leaked down between the liner and block into the air chamber when I first tore into it. I also saw over 200 degrees on the dash gauge right when I lost power and broke down. I’m hoping the O-rings will tell the story when I pull them out. Can you tell by looking at the O-ring if it failed?
davidb56
1,238
Bonners Ferry Idaho
I cant, maybe a diesel rebuild shop can.
bigmike
364
Dixon CA.
Update 1/25/2020
i had a buddy come by and he helped me pull all the pistons and liners. OMG, there was no way I could have done this myself. Right bank was definitely the side that failed. Pistons scored, rings destroyed, liners oval from the heat. I’ll be doing a full in-frame rebuild. Gonna replace the oil cooler since it’s probably full of metal. Huge thanks to Will Wagner, my ” on call” diesel mechanic.
bigmike
364
Dixon CA.
Valor,
crank rod bearing surfaces look real good. I’ll need to drop a main bearing to inspect.
bigmike
364
Dixon CA.
Update 1/26/2020:
pulled the oil cooler and cut open the oil filter. the filter had grit in it, as one would expect, I found maybe 3 minut pieces of metal 2 copper colored one silver.
Also made an adapter to extend my tire winch so I can remove supercharger and make it easy to use when it’s time to rebuild.
Tracer
14,278
Hawthorne, NV.
Good job Mike. Looks like your getting all the culprits identified. You should be a Detroit Guru when you get done with this.
Valor
228
Apple Valley, Ca.
Mike, how do the heads look? I agree with a previous post, you should get them crack checked. You've come to far to tear it all apart again.
Don't forget to check the fuse plugs in the cylinder heads. They are probably melted if it got hot but you can replace them for next time if it comes. It's behind that slotted head plug below the exhaust ports. Only one on each head.
