Adventure Driven
Been working on my truck allot and never noticed the front blue service glad hand leaking air only when I push the brakes, I don't recall this happening before, Is this normal?
Seth
Seth
I just checked the Air line diagram in the TM, it looks like the two way check valves under the drivers step is likely where the problem lies. The one behind the bumper is for the emergency gladhand. Here is a picture from the manual hope this helps.
Have you downloaded the 24P part TM? That's a good start for part numbers. The part manual give 'CAGE" codes as who makes the parts. You can uses this link here to see who the company is.Where can I get the parts and what are the part numbers?
1. If it twas a snake it would have bit you..... the very first forum on the very front page of this Steel Soldiers Bulletin Board contains links to the TM's (Tech. Manuals).Have you downloaded the 24P part TM? That's a good start for part numbers. ...
Hello!You can get kits to replace the diaphragms or new units & save the old units for rebuild. They also offer actual shuttle valve replacement units vs the ones with rubber diaphragms. Been there, done that, but no Tshirts were available. I had a similar problem with my truck & the repairs fixed the air leaking issues.
Pretty sure all these part numbers are in the parts spreadsheet sticky at top of this forumHello!
Do you have a part number for the repair kit?
Thanks!
Christian
For the entire check valve yes, but not for the repair kit...Pretty sure all these part numbers are in the parts spreadsheet sticky at top of this forum
which valve and I'll see if can find repair kit number....... and get it put into the spreadsheet. I help maintain the sheet along with Wes.For the entire check valve yes, but not for the repair kit...
Christian
This one: N30252B on TM ...-24P, page 383, item no. 18.which valve and I'll see if can find repair kit number....... and get it put into the spreadsheet. I help maintain the sheet along with Wes.
