gentrysgarage
- 118
- 43
- Lost Angels, CA
There are a few hydraulic threads on here involving some involving steering, winches and dump hoist. I read them all a few times,,,and sometimes the more you read the more confusing it gets…how much more so with the hydraulics where even the manufacturers are even trying to muddy the pond with numbers that don’t correlate with another manufacture and differing quality and much different performance it seems from the same design and capacity.
Originally, I was trying to see how I could get the hydraulics and equipment I had on hand could work together in the simplest fashion. Namely I have built my parts pile up to include the following: a ZF engine driven pump, a Ross HF 54 power steering gearbox, HydroMax master cylinder booster (hydroboost’s older and more muscular brother), Ford F550/Buss B700 disc brake, a WWII Garwood winch and an equally old WWII PTO driven Anthony hoist. I had a few options that quickly fell to the wayside.
First let’s see what was installed on the M35A3s…most info sourced here is from mudpuppy, grigeltaube and many, many others members contributing.
From Erik’s we get that the M35A3 engine driven hydraulic pump had the following specs:
PK13-16 ASCL NSN 43200-14422895 (for the Cat 3116)
12 GPM@1200RPM 2.46 c.i. 3000 psi Continuous 2 bolt flange/11 tooth max RPM 2500
From mudpuppy we get the M35A3 winch motor with the following specs:
RCSK16731 M30-106-7AS NSN 43200-1-441-7669 or 43200-01-441-7669
10.6 c.i. reverse displacement
The M35A3 pressure relief valve was set to 1750-1800 psi. A few guys have said that some were field shimmed to 2000 psi.
Let’s examine what I have on hand or on order:
Engine compartment:
ZF 7674955343 engine mounted 4.5 GPM CCW rotation 5.5-6.6 GPM @ 2400 psi (different sources different GPMs for the same puma. From a Bluebird bus.
Ross HF-54 steering gearbox.5 GPM @ 1500psi, max flow 6 GPM, increase GPM for steering assist cylinder based on size
HydroMax Master cylinder 3.2-5.0 GPM and a minimum 1000 psi
Transmission:
Chelsea 442 ZXUESX-W3XK PTO with 26/20 gear ratio SAE B 2 bolt flange. QUESTION: The comparable Muncie PTO is Opposite rotation so I would need a clockwise pump correct? NOTE: Forget finding rotation on the Chelsea webpage!
Bed/frame:
Prince SV 4 way spring center spool valve with solenoid/electric control rated at 12 GPM 3000 psi
Garwood 2U512 a WWII 10,000 lb pto winch
Anthony pto driven dump hoist that I have given up on using due to the price I would have to pay for a variable displacement pump to run both the winch and it.
In Part 2 we shall start our descent into the madness of hydraulic manufacturers wormhole of specifications that are all over the place and connecting the dots.
Engine compartment:
Transmission:
Bed/frame:
