Converting pto driven equipment to hydraulic and the decent into madness!!
davidb56
1,238
Bonners Ferry Idaho
D
Came across this and seems to be an interesting setup
Description:
GARWOOD / HOLAN M818 135 HYDRAULIC WINCH FROM A FORD C800. THE HYDRAULIC WINCH IS FROM THE M800 SERIES AND COMES WITH THE DRIVE PUMP. OVERALL DIMENSIONS MEASURES AT 68 1/2 INCHES LONG BY 20 3/4 INCHES TALL, BY 19 INCHES WIDE. THE DRUM LENGTH IS 17 3/4 INCHES, DRUM DIAMETER IS 8 INCHES, AND THE SPOOL WIRE MEASURES 1/2 INCH THICK.
View attachment 790960View attachment 790961View attachment 790962View attachment 790959View attachment 790958View attachment 790957
Does it come with another axle to support it? hahahahaha
gentrysgarage
118
Lost Angels, CA
HiYa davidb56,
Yep such a HEAVY geartrain, but of note is how the other guy overcame a deficiency/need with that geartrain! Probably needed the extra weight also LOL!
RustyStud was the first I remember that advocated for an electric on the front of his deuce, I sorta fell into it, as I got the HMMWV electric winch for the gin pole project...then learned that even the manufacturer stipulated in rather
LARGE and BOLD letters NOT TO BE USED FOR LIFTING! So I ended up with an electric winch that I will mount up front like the 2 of you guys!
