Stevekelley
- 2
- 1
- Glen Burnie, MD
I could use a couple studs and nuts.....ill buy them
The bolts for the wheel half’s can be found at NAPA.I could use a couple studs and nuts.....ill buy them
Awesome thanks!The bolts for the wheel half’s can be found at NAPA.
jack
Do you have the part number from NAPA? I went there and they couldn’t find a match.The bolts for the wheel half’s can be found at NAPA.
jack
Have them pull the book out with wheel studs. It took my guy some time to find the right one, I think I left the one I brought in. The one he found was maybe 1/8” shorter than the original. They did have to order it, only took a day or two.Do you have the part number from NAPA? I went there and they couldn’t find a match.
Those are wheel studs that are at napa. Not beadlock studs on the wheel. Only certain distributors sell thoseHave them pull the book out with wheel studs. It took my guy some time to find the right one, I think I left the one I brought in. The one he found was maybe 1/8” shorter than the original. They did have to order it, only took a day or two.
Jack
I got the beadlock studs at NAPA.Those are wheel studs that are at napa. Not beadlock studs on the wheel. Only certain distributors sell those
Maybe a moderator can adjust the title to be more specific. FMTV wheel beadlock studs would probably be accurate as that is what the OP was looking for. Not studs for the truck
A little late, I found the part # for the two piece wheel Bolt. This is what I used to replace one bolt on the wheel, I’m not sure if it’s actually a bead lock stud. NAPA # 641-3141I got the beadlock studs at NAPA.
These might work if you grind the needed flat spots? Wheel Studs
That link shows 7/16" studs. But we need 5/8"...These might work if you grind the needed flat spots? Wheel Studs
Seems questionable at best. With a childish comment like that, it's amazing that they've even dropped...
I was going to offer you a couple studs out of a bent wheel I had....AND enough new nuts to do all those wheels, since I have about 1200 new ones. AND they would've been all for the cost of shipping. But hey, you can spend your money now fool. Maybe Memphis can find you a towbar so you can drag that foot out of your mouth. D@mn youngin's and their mouths...
