803 not generating
55
9
whiting nj
My 803 has only 36 hrs on it and today while running with power out it started running weird and not generating. The engine was running (badly) and the generator barely turning. I shut it off and when I crank it only the generator turns. What came disconnected between engine and generator? Thanks. Jim.
bobs461
US
Sounds like the front half of your crankshaft snapped. The rear half is spinning the generator through the starter/ring gear...Ouch!
Sent from my SM-N950U using Tapatalk
bobs461
US
What about whatever bolts secure flywheel to crank?
Yes, that's true. If the flywheel bolts got sheared off (or fell out), the flywheel will spin the generator, and the engine won't spin. Hopefully, that's your only issue
bobs461
US
Pull the starter and see if you can diagnose the problem. Keep us posted
fosgittr
14
Midland, MI
Unfortunately, those bolts shearing off is usually the result of something else bad happening. I have seen both an 802 and and 803 now where a connecting rod end came off and caused the engine to seize, resulting in those bolts shearing off due to the massive force from the sudden stop. You may want to take a socket wrench and see if you can turn the engine using the main pulley bolt. If you feel solid resistance, there is something wrong in your crankcase.
55
9
whiting nj
Well- I finally got some time to tear it apart and found all 5 flywheel bolts sheared off. The engine was still running so the crankshaft wore the flywheel alignment step so it won’t center perfectly on crank. Gonna need a new flywheel. Anyone know where I might find one?
Ray70
7,222
West greenwich/RI
A new flywheel isn't gonna be cheap unless you can find someone parting out a machine.
Here's a new one but it's almost $300... which is still better than the $1000 GM Generators wants!
There are others available, but more expensive.
Just google 186-6467 and a handful will come up.
Chainbreaker
2,112
Oregon
But...what caused all 5 flywheel bolts to shear? Have you pulled the oil pan off yet to examine the lower end of engine? It might take some additional parts beyond just the flywheel. Might want to hold off on ordering a flywheel until you know status of engine.
You did mention that your engine was running badly after you lost AC out of generator. Wondering if you were running on 3 cylinders...?
9
whiting nj
Yes it was running but poorly. I was assuming with the flywheel not turning it had no balance or counterweight to keep it smooth. Although something else could be going on? And I am concerned about WHY the bolts broke. We’re they never torqued properly? Or did something else in engine cause that. Although I work on diesel trucks for a living and never seen flywheel bolts break regardless of the catastrophic event that took place.
