- 542
- 811
- 93
- Riverhead, NY
Yeah that's true. Also tested the transfer pump so in a worst case have that.
This would be good for the AUX fuel pump! In a pinch, we sometimes did that. Installed one that did not flow through, and took the good one we removed from the AUX position, and installed it as one of the other two pumps that had gone bad.Or a less than ideal swap (it does not flow through), but less expensive and OK if using in a pinch:
Facet Cylindrical Solid State 24v Electric Fuel Pump 40128E FMTV LMTV Military | eBay
40128E Facet Gold-Flo Fuel Pump, 24 Volt, 6.0-8.0, 33 GPH. New Facet Cylindrical Solid State 24v Electric Fuel Pump.www.ebay.com
Changing out the AUX pump, is something I would only do in desperation. Its a PITA. Or maybe if I was locked up someplace, and about ready to loose my mind.I was thinking dual purpose if he went into total failure again, one working pump (even if incorrect) working solo. But you can move it around too. All in what you really want to do.
Well its a fairly simple design, that's for sure.This is all there is.
Well I guess I was thinking more for long term. Now I see the pump is available new production. My initial fear was that these were no longer available new and that was the expense.
So that being said it makes sense to buy the right pump and have it for a spare. I also notes it would not be much fun to switch over the auxiliary as Guyfang pointed out.
So far this has been pretty fun. Emptied and took off the tank to clean it as best I could. Cleaned up the fuel level gage and the aux. Level sensor. Did the filters and pumps too.
Other than getting a few sets of clothes pretty well diesel soaked the biggest screw up has been washing them. Now the washer has a diesel smell even after cleaning cycle was run.
Fingers crossed my wife doesn't kill me after the next load...
! After 20 plus years in the Army coming home smelling like a diesel tank most every day, my wife told me she missed that smell. And here I thought it was just me!
That comes out to 18 gal/hour or nearly 40 liters/hour.Also, have you checked the pump output? 3 gallons in ten min.
I would not be too quick characterize the OEM Gold Flo series pumps as "unreliable" based on the issues you are currently experiencing with a generator, & its 2 pumps, that is new to you. Facet-Purolator pumps are widely used in construction equipment, agricultural, marine, utility, military applications and have a MTBF of up to 10,000 hours.I guess I don't view the original equipment pumps as reliable. My set came with two... one one dead when i bought it, the other caused my set to stall out a couple times last time I needed it for power. To get it going again I needed to take a wrench and tap on it in order for it start pumping again. Grounds are clean and connections are tight... but I would NEVER accuse my pumps of being reliable...
I don't disagree with what you've written... I meant to specify that I don't find MY pumps reliable. My dead pump has been disassembled, cleaned, rebuilt and EMI filter removed with no luck. In fact it shorts when connected... zero resistance from the 24V supply to the pump body (ground).I would not be too quick characterize the OEM Gold Flo series pumps as "unreliable" based on the issues you are currently experiencing with a generator, & its 2 pumps, that is new to you. Facet-Purolator pumps are widely used in construction equipment, agricultural, marine, utility, military applications and have a MTBF of up to 10,000 hours.
I have 4 generators, that's 12 of the OEM 480517E pumps with their original EMI filters intact, and have yet to experience a failure in any of them going back to 7 years of ownership with my first gen set. I do maintain them and use treated fuel and they have not ever had a hiccup...knock on wood!
I so recall SS members here that have brought, what they thought were dead pumps, back to life by dissembling the complete pump internals and cleaning them. You never know how long your generator may have sat with perhaps water in stale fuel that could have gummed up/corroded pump internals.
Regardless, if you truly have a dead pump with who knows how many hours on it then I agee its time to move on with a new pump. Nothing lasts forever.
