need hemtt Detroit Diesel 8v92ta mechanic near Sacramento
bigmike
355
Dixon CA.
Update 10/20/2020
everything is installed at this point. I had to order oil because apparently SAE 40 is hard to find. I’ll have it next Tuesday. I have the spare oil filter ready as well. Filled the radiator with 10 gallons plus 10 gallons of water. New batteries are next.
WillWagner
2,506
Monrovia, Ca.
Smoke leaking from the tailpipe yet? My D-max project made .....well, no smoke, still runs the same. Me thinks a "tuner" that was on it issue or a $800 sensor.
bigmike
355
Dixon CA.
Update 11/07/2020:
WE HAVE SMOKE!!!!
Yes folks, she fired up today...about time...
I built a device to pressurize the fuel system. I couldn’t believe how long it took to get fuel slowing. I used 10 PSI to get the fuel to flow thru the system. Good thing I did because I found 2 fuel lines loose. Here is my pressurizer rig. 10 PSI BTW.
