- 122
- 81
- 28
- Port Angeles, WA
Why do you have two threads for this problem? Please have one deleted. It makes old people like me crazy, trying to keep up with you.
This us the parallel cable. Different pins, much smaller. Will not work for the 60amp J1 port.Maybe you should ask @Suprman if these cables will work here... or at least to get better markings off them for you. Price is certanly right if so!
MILITARY TQG GENERATOR PARALLELING CABLE 6150-01-406-9533 88-22209 MEP 804A 805A | eBay
You are viewing a paralleling cable for the military tactical quiet generator series. This cable allows 2 generators to be run together in parallel operation. It is part 88-22209 nsn 6150-01-406-9533.www.ebay.com
plus shipping brings it over $500. A lot more than I would want to spend without it being a necessity.Thank you for pointing that out!! Actually seller does have a cable I could use, but it $400. A bit more than I would like to spend...
MILITARY DRASH & APPLIED GENERATOR 120/208 V 3-PH 4W 60HZ 60A POWER OUTPUT CABLE | eBay
Military 120/208 volt AC 3-phase 4 wire 60 amp 60hz power output cable. This is the standard military 120/208 60 amp 3 phase connection. Cable is approx 20 feet long. Plugs into the main output connector on the Applied HVAC gens.www.ebay.com
That's the correct cable, and not a bad price really. You can't buy the components for that.Thank you for pointing that out!! Actually seller does have a cable I could use, but it $400. A bit more than I would like to spend...
