M35A2 goes "clunk clunk clunk" in Reverse
doghead
4 Star General /Moderator
1,193
Trunnions refer to the center pivot point between the rear axles.
Dogbones are part of the rear axle suspension components. The ends of them have rubber that is known to fail over time. If one were to fail completely, it will allow the axle to move forward or rearward uncontrolled.
G-Longo
151
33
Houston, Tx
Curious if there’s any update on the clunk clunk clunk, my truck is doing the same after putting in reverse and going backwards a few feet to hear a clunk and feel the truck stop a bit like there’s something physically holding it back until it clunks again and is allowed to reverse again. I’ve gotten some feedback for what to start looking at but just want to know what this scenario played out to be
Dasgog
154
Tucson, AZ
Well for me it turned out that I had over greased the emergency brake fittings and as I drove the grease got between the brake pad and the drum and after driving it gets hot and sticks. Usually next morning it’ll go reverse. I had to take it all apart and clean with brake cleaner etc and was fine. For me it was just grease getting into the emergency brake.
G-Longo
151
33
Houston, Tx
Awesome!! Good stuff!! Thank you sir!
Bringeisen
Butler pa
Was wondering if there was an update to his update, I’m having the same problem. When sitting on a hill out of gear and no break the truck will slowly creep backwards or forward. With the truck off clutch pushed in it rolled fine forwards. Pulled into my drive way didn’t have a problem. Pulled into the yard started again. I did read about going from R-2 starting up can mess up some kind of clutch. And thoughts on that? Thank you
cattlerepairman
3,532
NORTH (Canada)
You are likely referring to the Sprag transfer case for front wheel engagement. If you have an air shift switch on the dash for front wheel engagement, this issue does not apply to your truck.
Often, it is the "moustache" spring missing or disengaged that holds the brake shoes for the parking brake away from the drum. If the shoes loosely drag on the drum they can clunk; in reverse they have a tendency to apply themselves and cause resistance.
Time for the TM and a peek at the parking brake!
Sent from my SM-G991W using Tapatalk
