- 1,946
- 1,648
- Laramie County, Wyoming
Been working on the truck the past week or so. Removed the Rube Goldberg winch/hoist thingy from the bed. Still bits and pieces that need removal but it’s gone. Pulled the solid front bumper off and reinstalled the split bumpers that came with the truck. I replaced the battery with a new one and she cranks right up. Won’t run because there’s no fuel getting to the carb from the gas tank. I used a trick my Dad taught me, pour a little gas into the carb. It starts, which tells me one the fuel delivery gets fixed she should run okay. I dug up a 12 volt fuel pump and I’ll scab it in next. While changing out the battery, I noticed there was a small cover attached to the “hump”. It’s held on by two wing nuts. I’ve got no idea what it’s purpose is. Pics will get posted the next day or so.
Still got a spaghetti mess of wiring. It appears the previous owner was in the midst of a complete rewire when he passed away. There’s a couple bundles not hooked to anything. The metal has a shiny silver color and the coating is a white fiber material over a Teflon inner wrap. Picture is attached. Any suggestions on what these wires are made of? I’ve got an older M-37 wiring harness to use as a template to return the wiring to a more stock look.
