Battery disconnect?
ramdough
1,732
Austin, Texas
The way i wired it up was to disconnect both 12v+ and 24v+ left negative hooked up
Just ordered my switch…. Will be in next week.
By any chance, do you know what size wire and lugs you used? I am not near my truck and want to Amazon my parts so it all arrives at the same time.
Thanks
Again!
Reworked LMTV
1,571
1,217
TN
I used 3/8 or 5/16 lugs 2/0, depending on which bolt you are connecting to on a typical military battery terminals. I replaced a bunch of terminals, so you may want to double check your sizes.
ramdough
1,732
Austin, Texas
Thanks! That helps. I will get supplies on order so I can get this done soon. I plan to do a lot of welding and wanted an easy kill switch.
