Jake59
- 102
- 43
- Kaggevinne, Flanders, belgium
Just a little helpful tip.
I built myself a light platform in rectangular tube with some scrap light square tubing and left over pieces of deck board, to fit onto any CUCV.
This makes it a lot easier to work in the engine bay, even more with lift kits and/or oversize tires.
The rectangular tubes are chosen to snugly fit over the shackle tubes and have been trimmed to reduce weight. I drilled a 1" hole to fit a locking pin through; otherwise the platform will slide off with you on it... ask me how I know...
There are 2 slide-down handles made of some #3 rebar bent in a U-shape with a nut welded to the ends of it, which you can see sticking out below the platform; to easily hold, lift and slide on/off the platform after the pins are pulled out. The handles are the 2 white lines you can see in the cut-out rectangular tubes.
As you can see, this is as wide as the CUCV, the slide-on tubes are 18" long with a walking depth of nearly 15", total weight about 25 LBS.
This setup really helps a lot when working on my CUCV... the older I get the more I appreciate this helper...
Cheers,
Jake
Cheers,
Jake
