When my brother got home he showed me this air hammer tool heās got. He said next time I could probably use it to punch the bushing right out. But this time I just did the torch method and they pulled out fairly easily. I know you mentioned you always paint the stuff you work on before, thatās kinda why I started doing it too. Stole a page outta your book
![Face with tears of joy :joy: š](https://cdn.jsdelivr.net/gh/joypixels/emoji-assets@5.0/png/64/1f602.png)
. I got the sway bar back on.
View attachment 840691View attachment 840692View attachment 840693
I got a little carried away with the grease gun and was going around town lubinā everyone up when I accidentally broke a nipple off one of the zerks on the top of the axle hub.
Itās actually the one on the other side that broke but itās that same location. The nipple is stuck in the grease gun fitting too and I wasnāt able to pop it out. I tried Vice grips and everything. Looks like Iāll need to replace the fitting on the grease gun and also replace that zerk on the axle. Do you know what type of zerk Iāll need for it? Luckily it broke off after I already pumped it full of grease.
[/Q
Did the bushings come with assembly lube?
