- 370
- 677
- 93
- Mansfield, PA
Hello. What is the inside bend radius? Looks like the dimensions are all "outside" dimensions? And to confirm, 18 ga crs, .048" thick?
Guy
Guy
True. But in this case there are only two "inward" bends that remain visible - and only with the door open: #3 and #5. None of them is critical, IMHO. Even if these came out too "sharp"; after several layers of paint it sure enough would look "factory stock" again......... When you see a repair done with smaller radius, it sticks out a mile away. ................
I think it's because it was listed as "ipcoating. Should be "Lpcoating".Put an @ right in front of the username.
Edit to add: I just tried but it doesn't seem to work, for this member....![]()
That would be my fault guess I can't read opsI think it's because it was listed as "ipcoating. Should be "Lpcoating".
Happened to me too - and it's not that we can't read...That would be my fault guess I can't read ops![]()
Yep, you pop up there, 2nd on the list... after typing an LPC in that search window...I think it's because it was listed as "ipcoating. Should be "Lpcoating".
Working on it right now....please review these numbers and verify that I'm correct.
