M35 rocker panel repair
lpcoating
851
Mansfield, PA
Hello. What is the inside bend radius? Looks like the dimensions are all "outside" dimensions? And to confirm, 18 ga crs, .048" thick?
Guy
gringeltaube
Staff Member
2,690
Montevideo/Uruguay
  • Yes, that's correct: 18 ga crs, (.048")
  • Yes, dims are outside. I could take some exact measurements on the finished parts, if needed. What really counts is my diagram on the right: mark work-piece as indicated and center the punch as precise as possible, on each of them.
  • Inside radius: I'd say minimum, just what results from using a std. punch & die set for bending #18 ga sheet metal. (I just used what was there in the shop: said to be a 85° punch with a .020" tip radius, on a 86° die with a .472" V-opening)
lpcoating
851
Mansfield, PA
I ask about the radius in an attempt to match the original. On the M151 parts, most of the panels are 18ga, .187" inside radius. When you see a repair done with smaller radius, it sticks out a mile away. I have a '54 M221 I could look at. I'd think that would be similar for the radius?
Guy
gringeltaube
Staff Member
2,690
Montevideo/Uruguay
........ When you see a repair done with smaller radius, it sticks out a mile away. ................
True. But in this case there are only two "inward" bends that remain visible - and only with the door open: #3 and #5. None of them is critical, IMHO. Even if these came out too "sharp"; after several layers of paint it sure enough would look "factory stock" again.
For everyone's peace of mind, I will try to measure and compare the radius in question, on different cabs, from different generations/manufacturers, and hopefully still "unmolested"....
Besides the outer rocker panel itself there is also a 90 deg angle piece, made of that same #18 #16ga sheet metal, that closes the rocker panel to the inside and joined with the cab floor. That area usually has rotted away at the same pace and needs to be replaced, as well. I will provide those dims, too. Same goes for the reinforcement U-channel that goes inside the rocker panel and the bracket that connects all this to the door jamb.
For those who have the skills and will to restore their cabs it would be great if all these parts would be offered as a kit.
Here, a few more close-ups while playing with my home-made parts.....
Cab repair 028 B.jpg Cab repair 029.jpg Cab repair 025.jpg Rocker panel replacement 002.jpg Cab repair 007.jpg Cab repair 008.jpg Cab repair 027 B.jpg Cab repair, cowl replacement 011.jpg Cab repair 04 026 B.jpg 20210810_130543.jpg
gringeltaube
Staff Member
2,690
Montevideo/Uruguay
That would be my fault guess I can't read ops:oops:
Happened to me too - and it's not that we can't read...:)
It's because the std. font for all our posts makes the lowercase "l" (L as in Lima) and the capital "I" (I as in India) look identical.
I think it's because it was listed as "ipcoating. Should be "Lpcoating".
Yep, you pop up there, 2nd on the list... after typing an LPC in that search window...
Thanks for clarifying.
lpcoating
851
Mansfield, PA
Okay, I'm struggling. Went through the pictures and prints. Made drawings in AutoCAD of what I interpreted. Numbers aren't adding up as you can see the interference in the drawing.
lpcoating
851
Mansfield, PA
All of the dimensions shown are "Outside" dimensions. What part is incorrect? I'm guessing it's the 18 ga profile.
Guy
lpcoating
851
Mansfield, PA
The change was from 3.063" to 3.144" on the profile. In this view it's shown as zero clearance, that will be adjusted so that parts properly fit without the use of a hammer. I still have to draw the 7 ga flat pattern but I'm getting there.
@gringeltaube - Gerhard - please review these numbers and verify that I'm correct. Thank you.
Guy
gringeltaube
Staff Member
2,690
Montevideo/Uruguay
Working on it right now....
OK, here you go.... See attached drawings, also in PDF, below.
(all to scale & done with the good old MS-Paint ;-) )
Also a few more pics....
20210821_110922.jpg 20210821_111717.jpg 20210821_112100.jpg 20210821_112513.jpg
Dimensions were taken from what I believe is an original section - and those "round" numbers all make sense - but not knowing the factory tolerances, the resulting drawing may not be an exact match to the original blueprint.
Anyway, this should be good enough for our purpose and everything adds up correctly, that way.
Edit: Just added a second drawing now, showing dims of that 90° angle piece, and where it goes, spot-welded in place...
Many thanks to @lpcoating for your dedication and patience...!:grd:
Needless to say: this boxed- and not totally sealed- design is the perfect trap for moisture and dirt. No way to flush/rinse all those hollow spaces or even keep them dry, so rust will soon develop there and start "eating" our precious work - unless all parts were phosphatized and then painted with some zinc rich primer, before final assembly.
lpcoating
851
Mansfield, PA
So we are in the process of installing a iron phosphate system along with a powder coating batch system and we have a liquid spray booth. So what you mentioned could be an option at CMD.
Guy
