cucvrus
- 9,958
- Jonestown Pennsylvania
Fits the description of a few CUCV's I have had sent to me for repairs. AHH NO I can't fix that thing.
Why is it that I see repairs done like this all the time? Tools and money can make fools of some people. Do it right the first time and drive on. Be SAFE.
.I have the fuse box and bulkhead connector back in the firewall and all connected. I also have the steering column in place and all the wires plugged in for testing purposes. So far so good. I don't have the column bolted into the truck or hooked up to the steering shaft. Just the 2 under dash bolts holding it in. No steering wheel attached but everything works as planned. I found a lot of hacking in this truck. WOW. And this stuff was going on right next door to my shop. They were asking me questions for 20 years about how to fix things on the CUCV's. I only intervened as needed when they were stuck and unable to repair certain things. I think back and know now I wasted a lot of time explaining how things are supposed to be done. I think most people think a quick slam bam cheap repair is the best repair. I see many types of vehicles that are repaired this way. Hack it, pack it then ship it out. It still works. NOT. Take Care do it right the first time. Do or do not. There is no try.
.View attachment 843994The box is back in and the bulkhead connection rejoined. View attachment 843995 View attachment 843996 I like the hinge that is on the upper side of the drivers door.View attachment 843997 May I recommend if you ever have to work under the dash on the fuse box it is very helpful to remove the door and the drivers seat. Makes childs play of the whole job. No standing on your head and twisting your neck and back. Work Smarter Not Harder. WSNH. View attachment 843998 10 years ago this vehicle was scrapped and set out in the back. One winter I needed it and spent a few days welding in a floor and heavy angle for rockers. It was scrap and was marked for scrap. That was 2010. it is still going. View attachment 843998 View attachment 843999 After I had everything installed and tight it was time for some testing. I have the horn circuit working again. Just need the $7.00 spring contact kit. View attachment 844000 Power down the horn hole and grounded on the steering shaft. Test light lights. View attachment 844001 Screwdriver crossed from positive probe to ground steering shaft and horn sounds. This an August 1983 build date truck. View attachment 844003
So I have no shame in the rust it has. It will never leave here alive anyway. View attachment 844002 Take Care. I could have left it die a few times now. It has to keep going. It plows nice in tight areas and just keeps going and going.
