36racin
- 14
- 8
- Gonzales, La
Purchased what I thought and what was advertized as a MEP701A 3k gen 3-4 years ago. with the ask covers. When i remove the top cover today the tag says it's a MEP 016B . From what I have seen they are the same....Onan powered....Completed the battery modification, did all maintenance on it and got it running. At the time was making 110V power. And then it sat for several years......... Hurricane Ida came thru forcing me to need it again so I went thur everything....Replace bad batteries and attempted to start.....NOT getting fuel. Pumped manual lever until all was full and returning to the tank. But not getting fuel to the injector. Solenoid is working but the shaft going inside the fuel pump was stuck. Worked it loose(and broke the plastic linkage) doing so. Will need one of those too. Still no fuel to the injector, Can get it to pop off with eather. So I know it will start(eventually) once I figure this fuel issue out. Any suggestions?? Anyone close to Baton Rouge with a 701 or 016 that can assist?
No real house damage other than singles and wood fence....so we are currently ok....Want to use the diesel gen on my pool pump and water well pump.....My little Yamaha gen cant handle all that....
Thanks,
Todd
Thanks,
Todd
