jplace1011
- 488
- 63
- Santa Ana, CA
I can’t get this speedometer working for the life of me!
I have a CUCV M1009. Late last year I had the speedometer cable (provided by the previous owner) and the nylon gear in the transfer case north replaced, because the speedometer wasn’t working when we purchased it.
A month or so ago it stopped working. I purchased a used speedometer adapter from a very helpful guy on here. It’s still not working! In fact I installed the replacement and drove it 20 feet and then checked it. The needle got stuck into the transfer case end. What the?
One thing to note is it does work if I place the speedometer cable into the transfer case. It’s however not accurate. The cable end spins easily and so does, the nylon gear seems good still as well.
I’ve noticed (with both adapters) that the cable doesn’t go completely into the adapter. There is a small gap (see pic). Could it be the position of the adapter? I put it all back as I found it.
Any ideas, maybe the cable is wrong/damaged? Maybe the end of the cable is too long?
Thank you in advance. This thing is becoming a real stumper!
