tlflow
- 58
- 13
- Kountze, Republic of Texas
I have had recurring front axle seal leak on passenger side. the inner axle was pitted pretty badly under the seal lip.
I used a Speedy Sleeve SKF99212 I had to make a 'tool' to install the little tool they supplied fits in a 2" NPT union sso you can cut off the end after you JB weld it in there. I also blued it and filed down the high spots. I smoothed and cleaned up the surface before the install but I'm a little too OCD and couldn't help myself
Also replaced the spindle bushing, since the load is carried there
![SKF Installed.jpg SKF Installed.jpg](https://www.steelsoldiers.com/data/attachments/613/613771-110ce7c74992a13d3434da387159dbbb.jpg)
![speedy Sleeve SKF99212.jpg speedy Sleeve SKF99212.jpg](https://www.steelsoldiers.com/data/attachments/613/613770-c75c70bb7149ec9c594ebfcad2a43229.jpg)
