front axle seal leak
tlflow
58
13
Kountze, Republic of Texas
I have had recurring front axle seal leak on passenger side. the inner axle was pitted pretty badly under the seal lip.
I used a Speedy Sleeve SKF99212 I had to make a 'tool' to install the little tool they supplied fits in a 2" NPT union sso you can cut off the end after you JB weld it in there. I also blued it and filed down the high spots. I smoothed and cleaned up the surface before the install but I'm a little too OCD and couldn't help myself
Also replaced the spindle bushing, since the load is carried there
INFChief
1,343
New York
View attachment 858459 View attachment 858460
That’s a wheel seal. Axle seal is generally inside the axle housing and seals against fluid running along the axle shaft and escaping in to the hub.
