ANG3CHEAPSHOT
- 26
- 18
- California
I don’t mean to be hijacking this thread. Will start a separate thread on my growing list of modifications later. But answering your question and related to the original fuel pump replacement you started this thread with;
Fuel pump is a “Raptor R1SBU369”. Comes factory preset at 8 psi.
Fuel filter is a “Racor Fuel Filter / Water Separator 500FGSS, using a 10 micron filter cartridge“.
I disassembled and painted it black myself.
Various fittings and fuel hose sourced from Vulcan Performance and NAPA.
Placement of these on your MV is entirely up to you. I mounted them where MogMan placed his because I can stand right next to them and service them at waist height. It is the most logical placement on the Humvee.
I suggest using mounting plates with 1/4” rubber pads on both sides of the plastic splashguard to mitigate vibration, distribute the weight, and not risk cracking the plastic. I cut the pads from a 96 inch roll of rubber purchased from Tractor Supply. I used some stainless plates I had laying around my extremely cluttered shop. Have moved them around countless times in the past thinking I would eventually have use for them. Maybe someone out there in the SS community can relate to that. My family says I am a hoarder…..they just don’t understand!
Thank you for your interest. I am close to completing the mod and will post pictures when complete. Please post pictures of your’s, if and when.
do you know if there is a comparable fuel filter/water separator for the Racon 500FGSS? I’m not sure what the FGSS stands for. That particular model seems to be sold out everywhere.I don’t mean to be hijacking this thread. Will start a separate thread on my growing list of modifications later. But answering your question and related to the original fuel pump replacement you started this thread with;
