Madball90
- 26
- 18
- California
Ahhh ok….I traced all the wires, checked all the bulbs, replaced all the relays converted all to fuses, signal goes up the steering column does not come out on the lead to the drivers rear wire. When I jumped the wire on the engine side of the firewall from front blinker to rear tail/flasher everything from there down worked. traced signal from the flasher down to the switch and dashboard wiring harness. In fact just pulled up old messages you told me it was turn signal cam, about 6-8 months ago.
