Hydrolocked, big repair ahead.
Gcelevator
797
Fort Lauderdale, Florida USA
Retiredwarehouse is a stand up guy and I bought stuff from him and he was so helpful. Try to pm him again and if you buy it from him he will probably be there to answer your questions.
what did you use for body lift? I bought 12 of the upper mounts that I was going to vulcanize and stack
I bought 12 hockey pucks. Works perfect. Might change it in the future as does not match the size of the original body mount. I also thought about making it out of starboard. As of now it works.
Mogman
10,495
Papalote, TX
I have been using this guy REAL HAPPY with his stuff, will build many different Dia., thicknesses and hole size to order.
https://www.mikellisbodylifts.com/shopmiscellaneous/hummer-h1-2-body-blocks
eBay link
Maxjeep1
1,930
Las Vegas Nevada
I got the new upper mounts for 8.00 dollars from AMGeneral and after I ordered them they went up to like 30.00
Gcelevator
797
Yeah, they have lost total respect for our money jajaja. I might replace the ones i used in the future, at least the rear ones as they look funny on the truck not matching the original mounts.
Maxjeep1
1,930
Las Vegas Nevada
I thought the stock options were the best for the money and my thinking was if one is good two is better. Lol
Mogman
10,495
Papalote, TX
The parts TM does not show a gasket, I doubt you can get a civi cross for the pump as it has a vent nipple that civi vehicles do not have.
REF
135
Porterville Calif
I could not find that gasket in the TM, But I could not stop the exhaust leak. The gasket shown is a Fel pro 60718 / Mahle F7507 / Victor-Reinz 711365500.I went to rockauto.com and looked at a 98 hummer H1. Its a 2 3/32" gasket, the metal lip on the flat side fits tight into the cast neck (turbo down pipe) and the bevel faces the pipe.
Note: can be a bear to get started strait into the cast without bending the lip -- buy 2
Gcelevator
797
thanks man. will order right now.
