- 444
- 1,663
- 93
- Miles City, Montana
Lots of built up corrosion in there, going to just replace it along with the air drier filter and such..
Good find and happily easy to clean and/or replace!
Depending on which dryer it has on it. It tends to be cheaper to replace the whole dryer unit than to replace the obsolete filtersLots of built up corrosion in there, going to just replace it along with the air drier filter and such.
I'm looking at $190 for the obsolete filter versus $360 for the whole unit.Depending on which dryer it has on it. It tends to be cheaper to replace the whole dryer unit than to replace the obsolete filters
AD-9 dryers are common commercial dryers so most truck parts places have spare filtersI'm looking at $190 for the obsolete filter versus $360 for the whole unit.
Got one of those on my other semi and yes definitely needed as I'm not running alcohol in my air tanks. Straight bolt up for the air lines or is there some adaptation to size of the lines?AD-9 dryers are common commercial dryers so most truck parts places have spare filters
The pure air plus dryers used on the 5 tons have a bad habit of hanging the purge valve wide open even after new purge valves or rebuilds they still stick open.
AD9s come with a 12v heater only so you have to swap the heater out. A critical part in Montana
I use an armada brand AD9 dryer on everything from my local parts place
AD9 24v heater swap
5005037 Purge Valve Kit for Ad9 Dryers by Bendix for sale online | eBay
Find many great new & used options and get the best deals for 5005037 Purge Valve Kit for Ad9 Dryers by Bendix at the best online prices at eBay! Free shipping for many products!www.ebay.com
Ad-9 dryer
Bendix style AD-9 Air Dryer 065225, 109685 ***NEW AFTERMARKET*** 1 yr warranty! | eBay
Replaces multiple part numbers including 109685, 109685X, 065225, 065225X. Bendix Style AD-9 AIR DRYER. Specializing in Air Brake Components including Air Compressors. Air dryers. Air Valves. Air over Hydraulic Brake Devices.www.ebay.com
You may need a 1/2" m to 3/8" f bushing adapter as some air plus units use a 3/8 female. The AD9s are 1/2"Got one of those on my other semi and yes definitely needed as I'm not running alcohol in my air tanks. Straight bolt up for the air lines or is there some adaptation to size of the lines?
I have the NF50011F Pure Air Plus currently on the MV.
Thanks, I'm trying to not work on it too much till get my pole barn done. Just doing basic necessities to make it safe for use until then. I'm sure I will add another one or two to the fleet since I need to replace my semi next in the future.Congratulations on your truck !! Kind of fun to work on, did I really say that lol I got 6 trucks know. 3 m936, m931a1, m9?? Troop carrier motor shot, Hemtt 978.
See you are in North Dakota, what are you doing with that troop carrier rig and are they drop sides that you are willing to sell on it?Congratulations on your truck !! Kind of fun to work on, did I really say that lol I got 6 trucks know. 3 m936, m931a1, m9?? Troop carrier motor shot, Hemtt 978.
