WTK: LMTV Shock absorber options
coachgeo
3,546
North of Cincy OH
Has anyone came up with a cross reference for shock absorbers for LMTV? I see Fox has some but they're evidently in limited supplies.
looking at your Fbook... looks like you have 6x6 rear axle. or is that a high pinion newer single LMTV axle?? .. if 6x6 is it staying 6x6 with your mods... or ??
Ronmar
8,316
Port angeles wa
The possible issue with that Monroe 65485 in the parts listing is it is several inches shorter than the original shocks.
the specs for the shocks(A0 anyway) are:
20.94” compressed to 33.26” fully extended under 16mm bolt on one end. Thats 12.32” of travel…
5/8”/16MM top and 7/8”/22MM bottom bolt shank diameters. This shock dimension was obviously chosen for the expected range of travel
Something like a Monroe 65456 @ 20.25“- 32.88” might be a better match for the expected range of travel. Monroe specs them for class6-class8 trucks so the weights are in the ballpark… You would of course have to fab bushings/spacers to match up with the mounting bolts, but that is going to be true of most shocks you choose…
here is a link to one of several threads on that subject…
https://www.steelsoldiers.com/threads/lmtv-shocks-absorbers.140362/
coachgeo
3,546
North of Cincy OH
thanks for update on the other Monro Model. I know the 65485 one has been used successfully... maybe cause they are a bit stiffer than OEM?. The OEM appear to be, even at new...... extremely soft. The 65456 should then be even better
Ronmar
8,316
Port angeles wa
Well they are pretty HD shocks, it might also be that the ones in use havn’t been hammered enough off-road to beat them into submission…
Third From Texas
6,669
Corpus Christi Texas
King makes one:
And Seth runs ICON's on his M1079 (Brutus):
No model numbers, sorry.
Ideally, you'd want to do it right at those prices. If you go with a racing shock, get with a salesman/tech and go over your weight/corner weights/travels. Then they can calculate the right body and valving.
When you get into that many zeros in the price, do it right. Honestly, I'd go with 3" bodies, remotes, and skip the bypasses (with this much weight your rebound adjustment, etc isn't really of much use).
wgtactical
431
Carrollton, Georgia
My high pinion axle is a modified 6x6 axle. My intentions was to purchase a ready to use axle and I am confident the gentleman who sold it as such thought that was what he had. After having to cut five of the six brackets off and properly locate them, I can now consider myself qualified to do another :LOL:
Like anything, if I had this project to do over I at least know what I am now trying to accomplish I suppose...
Ronmar
8,316
Port angeles wa
I had talked with a ranco rep and they made long enough ones, but when i started giving him vehicle weights he was not thinking they would be appropriat(meant for lifted pickups?)... that was a while back though. He did suggest a large class truck shock and i related the difficulty i was having finding one long enough@ 33.25"
Then i came across the 65456, which is within 1/2" of the original A0 shock extended length(ithink it is the longest monroe makes) and it compresses approx 1/2" shorter than the oe shock. But it is in an appropriate weight class...
j_boucher
110
Virginia
Did you ever install the 65456 ?
j_boucher
110
Virginia
So I ordered some Monroe Magnum 65456 but they are way to short , are there two versions of these shocks? I measured the 65456 and extended its 26" but the Monroe chart is stating EXT is 32.88.
Edit - Never mind seems the one I opened was different then the other three / others fit perfectly / I will need to go to tractor store to get an insert for the shock eyelet bushing the are pretty big and even the lower bolt which is pretty big has slop in it . Looks like the first shock has been miss labeled
