Huertam96
- 12
- 3
- Houston tx
Went to orielys to buy some new glow plugs but they didn’t have the correct ones. The male part was bigger than the glow plugs I originally have. Where could I order them from ?
How were you able to successfully trim them ?You may need to trim the connector on the glow plugs. I had to do that on the ones I bought. They work really well.
Thank you all for the help it is much appreciatedAC Delco 13G are a direct fit. No trimming.
28 years of driving CUCV's and never used anything but the Ac Delco 13G. I never walked anywhere or had exploding glow plugs. It's sounds exciting. What must I do to have my glow plugs explode? I just want to be able to say I been there and done that. I did convert several back to stock with the ballasts and all. Take Care and Be Safe. Don't abort a stock CUCV. The TM's are useless after that.AC Delco 13G are a direct fit. No trimming.
I like your point here. Question. I am "can open the hood" kind of guy. I daily drive a m1008 and it has a manual glow plug momentary button. When it is anywhere between 50-65 degrees outside it takes a good 10 seconds of glow plugs to get it to fire off. I have been assuming I should look into replacing my glow plugs. What is the "correct" or advised glow plug time required to get the 6.2 to get going?I don’t try to start or continue online arguments. Way too many ways to interpret the written word wrong and get a feud started when none was intended.
With that written, this is an observation. Not an argument. You are very correct that an all stock CUCV glow plug and starting system works excellent when all of the components are correct and working properly. The problems I have seen happen when people modify the stock system. Often it was done by a previous owner and the new owner has no idea of the modification. This part of the country really doesn’t have a winter. We just have a few days below 45° sandwiched between 80° days. Today is one of those days. 42° this morning and it was 78° yesterday.
2 or 3 semi functioning glow plugs would have started a 6.2 yesterday. Today might require at least half of them working. With that in mind it seems very common for people to put a momentary switch on the blue wire to manually activate the glow plugs. Or some other “hot wire” modification to make the engine start on days like today. The rest of the time it really doesn’t matter to some people. I am not one of those people.
But I have seen the results of such modifications. I have had to slide hammer remove many glow plugs on engines that came to me with them already swollen. I have also had just the threaded base come out with nothing else anywhere in the precup or cylinder. Exploding and swelling glow plugs do happen is my experience.
This forum and just about every forum I visit has a requirement for members to list their location. We all see the at least weekly admonishments by moderators for people to actually do that. So, even though I would like to have all members fill out a mechanical skills and understanding questionnaire on sign up. It just isn’t practical. So, when people post a question there is no green wrench next to their name signifying they know what a volt is, have a 10mm socket wrench and can open the hood without assistance.
That leaves us with several options when replying to a question. Assume they know nothing or assume they are an ASE master. We also have to figure out the condition of their vehicle. Bone stock or modified.
This particular thread was going in the “can open the hood” and “truck has been modified” direction. 13G glow plugs in a modified momentary switch glow plug system will swell or explode if used improperly. I have personally dealt with the aftermath on other peoples vehicles. 60G glow plugs will not. They might burn out and need to be replaced, but the entire glow plug will come out of the engine with ease.
We are all individual owners of our vehicles and can do as we wish with them. What is correct to some is outrageously wrong to others. The important part is what is “right” for the owner of the vehicles.
10-12 seconds are the guideline I have follwed.I like your point here. Question. I am "can open the hood" kind of guy. I daily drive a m1008 and it has a manual glow plug momentary button. When it is anywhere between 50-65 degrees outside it takes a good 10 seconds of glow plugs to get it to fire off. I have been assuming I should look into replacing my glow plugs. What is the "correct" or advised glow plug time required to get the 6.2 to get going?
.10-12 seconds are the guideline I have follwed.
I don't know why I can't download this pdf. I can only view it on the webpage.
Good luck.
Damn. I just realized you already posted this.This helps you:
