TNDRIVER
571
Cleveland,TN
Rear toe alignment using string method. Really fun and effective for a low buck correction. Used greased fiber board for slip plates.
LR was almost 2” toe out, RR was 1”. Specs must have been a lot different on the 1151 with 1500+ lbs of armor pre demil.
Set total rear toe out about 1/8” as I will be running it unloaded most of the time.
NOW.........................Please explain your method of setting the thrust angle......................Inquiring minds want to know??? Me, I'm just curious.
rcamacho
916
Bainbridge Island Wa
Enhanced string method sets parallel from center of hubs. Essentially a square box
Thrust is controlled by even toe on each tire relative to square box.
rcamacho
916
Torqued front subframe. Front rear most bracket was loose on frame. Enough deflection to show during steering and cause a noticeable click.
Latter feels resolved now and all other new / rebuilt steering components validated good & tight.
Checked torque on all control arms and shocks for good measure.
rcamacho
916
Replaced all LH bank injector return lines. Found the first hose from the return hard line to the #1 injector was loose. Whomever installed it missed getting the retaining clip over the injector return fitting.
Of note, on the ECV with 200A alternator access is a bear to #1. I came very close to pulling the alternator for better access. Creative automotive yoga prevailed though.
I used the braided kit from Badger Diesel. We’ll see how this line holds up sans clips.
jake20
848
Illinois
Oh man I can’t even complain about the 200s, the 400s really suck. You can’t get the fuel filter out, you can barely reach glow plugs and injectors, they start eating through the body harness after a while, and I personally don’t know anyone who needs an alternator that makes 10Kw lol.
Maybe I’d run one if I had a large pure sine wave inverter to hook into a house, but otherwise meh.
I recently swapped a 400 for a 200, man what a world of difference. My main reason for swapping it was the 400 screeching when spooling down after revving.
Mainsail
1,800
Puget Sound, WA
I hear something like that when it shifts from high RPM to low, and assumed it was the turbo overloading and opening the wastegate. I hear a similar sound when I shut the engine down.
EDIT to add: I didn't find the 400 amp alternator any bother when changing the glow plugs since they're so easily accessed from underneath.
jake20
848
Illinois
Yea it was very apparent on mine. Open the hood and rev the engine with your hand on the injection pump throttle lever, you’ll find out pretty quick if it’s the alt.
jake20
848
Illinois
Made some progress on the chicken shield
Awesome, what’d you use to replicate the measurements and how did you cut it out? Your setup looks slightly bulkier than mine, I had to keep weight in mind with my older style turret bearing.
Don’t think I ever posted pics of my finished one either.
I basically copied it off an existing steel one and cut it out of an aluminum sheet. Had a buddy bend the corner with a brake at a fabrication shop.
