therealquaid
- 101
- 33
- California
@montaillou Thinking about availability of some of the mods people have mentioned in this thread, I’m curious if it would be possible to add a beadlock system to a rim like Boyce’s or if you know of anyone who might supply beadlocked rims for a deuce with less backspacing in order to have the wheels tracking wider for more clearance on 395s?About power steering, the only guys I know of supplying wheels with a negative offset that fits a PS kit on a Deuce is Boyce, and their wheels don’t have beadlocks. This limits airing down the tires to about 40psi vs 10~15psi with a beadlock wheel without power-steering (or at least with a smaller turning radius due to 395s rubbing on the pitman arm).
Unless you can weld and fab your own wheel it seems like for anyone looking into buying parts for these modifications you are limited to hydraulic assist power steering with a 40psi minimum tire pressure. For the terrain shown in the video this would be more than enough but then the truck would lose versatility on sand…
All suppliers I’ve seen suggested on older SS threads have since stopped offering these rims, limiting this feature to a 100% DIY job (which is preferrable if someone has the tools/know-how), but is not as accessible.
