Autonomy_Lost
- 1,554
- 93
- Pennsylvania
I wonder if you can open them up and modify them?
Exactly what I want to do!I've searched and read through all the spring threads I can find. Lots of good info, but little "follow on" reports of how the trucks ride. Right now I figure our M1123 has had at least 3k pounds of gear removed, so the springs are like bricks. Here is my goal, and I would appreciate anyone who has experience that can help me get to it
So, back to the M1123. This truck has enough wheel travel to put the RR to shame. There is no need for solid rock springs. I would like to drop the rates...a LOT!! Most of the springs I find in the forum are advertising 30% less rate. They all advertise this 30% less rate as though it is a magical fix. Honestly, 30% less rate only accounts for the weight removed in the demil. That takes it from "solid" suspension to "dump truck" rates. I want 1965 Fleetwood spring rates.
In fact, I think the optimum for my use would be springs that would bottom frequently, with the stock ride height, and then stiffen it up with air shocks when needed. I want to glide down the road in my living room couch. The HMMWV weighs very close to what a '65 Cadi weighed, so I know it's possible.
Is this a real risk? Obviously an instantaneous release of immense pressure is potentially deadly, but is it likely? I thought jeep guys ran setups like that, too.Be careful.. That shock installed is the only thing keeping that spring from decapittating someone..
The shock is what keeps the suspension from extending too far. If it does extend too far, there is potential for the spring to shift in it's seat and potentially come out. Our springs don't really have much extension to begin with.Is this a real risk? Obviously an instantaneous release of immense pressure is potentially deadly, but is it likely? I thought jeep guys ran setups like that, too.
While not their intended use, would some 17” limiting straps attached to the stock shock mounting points do the trick? Seems like it would be some margin of safety keeping the spring in place while also keeping the entire assembly from overextending for the rare chance that one reaches full extension.The shock is what keeps the suspension from extending too far. If it does extend too far, there is potential for the spring to shift in it's seat and potentially come out. Our springs don't really have much extension to begin with.
For most jeeps, you're talking limiting straps or just suspension geometry that keeps the spring in place. Most Jeeps are also solid axle, not independent suspension, which changes things up a bit.
I have no idea how likely it is, but it's definitely not impossible.
Some sort of limiting strap should work, but remember they aren't typically designed for shock loading, which is what will happen during rough driving. The shock slows down how fast the spring can extend, and mitigated the shock factor (no pun intended) of the suspension travel coming to a stop.While not their intended use, would some 17” limiting straps attached to the stock shock mounting points do the trick? Seems like it would be some margin of safety keeping the spring in place while also keeping the entire assembly from overextending for the rare chance that one reaches full extension.
Thoughts?
Service TM gives the correct procedure for spring replacement. Fairly easy at least with the stock height springs in my experience. I’ve replaced (4) coil springs to date on the HMMWV platform.I see this thread has been thriving without me! There is a lot of good info.
My quest for a softer suspension has come to a head. Our 2004 Range Rover died, and it is the vehicle we tow across the country behind the RV. Last year we ran Poohkeepsie Trail in Colorado. When we got off, nobody believed we ran it in a stock RR...but I think it was the cars last hurraah. The tranny went out 6 months later, and it would cost more than the car is worth to repair. Oh well.
So...If I can get the suspension on the 1123 smooth(er), I would like to tow it. The other option is to have to buy another car...and there are not many "towable" options anymore. I've had the 1123 3 years now, and will not allow my Wife to ride in it with her bad back. It's time to get serious.
I am thinking I might try the Armada springs, as they are cheaper than all the HMV options. Then remove the sway bar. Finally, find some weak ass shocks, since it sounds like the shocks hurt more than help, based on what you guys have been doing.
A quick question...from the repair work I've done on the HMV the last 3 years. It appears that if you undo the shocks and raise the frame, the springs will drop out. Is that correct? Or is a spring compressor still required?
A. I'm not a mechanic nor even pretend to be. B The front springs are not too bad but the rear should be left to the "talented" shade tree bunch. Screw it up and they can put your lights out! My two cents.I see this thread has been thriving without me! There is a lot of good info.
The Armada Springs may sag under the weight of the newer frame in the M1123I see this thread has been thriving without me! There is a lot of good info.
Just out of curiosity, what tire pressures are you running? When I got my M1123 last June, I originally ran 40 PSI in all four, and could have sworn fillings in my teeth fell out on the road, couldn't even imagine off roading....
I’m certain most of us are running civilian truck/SUV/car pressures. We should keep in mind that these are designed for military applications, they have beadlocks or runflats for a reason.I am running a lot more pressure than 15-20! My tires suck right now. I think they sat flat for months, as they all have flat spots. I initially over filled them in an attempt to remove the flat spots, but it has not worked. When all the flat spots line up on the road the rig shakes like crazy...then they slowly roll out of alignment and it reduces to a mild shake.
I'll try the lower pressures and see how she rides. Thanks!
Did you replace the runflats with PVC beadlocks?A couple updates...
I removed the runflat inserts...
