BERZERKER888
- 895
- 93
- Daytona, FL
What steering wheel are you installing?disregard....it appears the autistic mildly retarded 18 yoa army " mechanic " stripped out the threads... I re-tapped to a larger size..wheel is off.. as Filner says " I win"..
the Dorman wheel that Dave, Sean and. chad Installed..What steering wheel are you installing?
Chad from Broke Overland has an excellent video of the install.
Did you notice that Chad decked his steering wheel on a mill.Chad from Broke Overland has an excellent video of the install.
Use the @ sign... @Keith KnightTagging in [mention]Keith Knight [/mention]
He is looking at steering wheels too.
yes and yes....Sean used a cut off wheel..still worked but...Did you notice that Chad decked his steering wheel on a mill.
Are you doing that as well?
yeah / sorta a fellow has a leather steer wheel cover for the OEM steering wheel now. Just saw it recently bu dont recall whereKeith Knight said:I’ve been looking for an OEM style that would match that steering wheel but with leather. Anyone come across such a thing?
.I've toyed with the idea of a FL wheel (I want the cruise switches, horn, and a mic key switch and the center piece on the Cascadia would be perfect for my plans).
I'm hesitant to go with the smaller diameter after hearing some feedback, though.
There's a reason big trucks have big wheels.
If your p/s ever goes out on a trail, every inch in diameter is gold and that's a noticeable drop in leverage down to an 18" wheel in any event.
The modder/fabricator in me would really like to replace the entire column with something that has actual tilt and tele.
Pretty sure I'll skip the airbags, though. LOL
I don't know for sure but it's likely metric and so probably the same since the stock wheel is really just a Steyr wheel from Germany.Old thread, I know, but does anyone know what size and thread pitch that is in the wheel. In the Dorman it's an M8.
.I’m considering taking my original steering wheel off and send to a company to and have it professionally wrapped with leather.
