Basic paint prep and tons of sanding to include heavy degreaser and using a hot pressure wash. Paint and primer are single stage urethane that use catalyst and reducers then shot through a cheap Lowes HVLP gun.Looks great! What was your process? Rattle cans or what? I hope to start painting mine soon.
Thanks for info. Looks really good. Hope mine turns out that well.Basic paint prep and tons of sanding to include heavy degreaser and using a hot pressure wash. Paint and primer are single stage urethane that use catalyst and reducers then shot through a cheap Lowes HVLP gun.
Don't forget your PPE!!Thanks for info. Looks really good. Hope mine turns out that well.
Not much to it, it’s all in the prep. If you see something questionable, fix it and don’t get in a hurry when spraying, it might take several applications to avoid runs. You got this!Thanks for info. Looks really good. Hope mine turns out that well.
It started right up and drives but pulls to the right, someone local is going to show me how to align it. Alternator rattles a bit but other than that I’ve still been driving it after a full lube up. Need to figure out why the heater doesn’t blow on the drivers side floor because that will hurt my ability to drive it in winter.How did your HMMWV look on arrival? Progress?
Address the alt ASAP, usually loose and or broken bolts.It started right up and drives but pulls to the right, someone local is going to show me how to align it. Alternator rattles a bit but other than that I’ve still been driving it after a full lube up. Need to figure out why the heater doesn’t blow on the drivers side floor because that will hurt my ability to drive it in winter.
