I have had issues with the speedometer and the cable is broken. Speedo hasn't been accurate since 1600s and now it's off by more than 30 mph when cruising at 40mph by GPS. Instead of buying a new cable, I decided it was time for an upgrade. I bought an autometer GPS speedometer. I wasn't a huge fan of the gauge color but if I need to replace down the road, this series of gauges has everything I need but the voltage gauge. It's high quality and it will be accurate regardless of tires I run on the truck.
I had to step the power down on this gauge. Gauge runs on 12v or 16v. So I bought that 24v to 12v converter. I decided I wanted the gauge to get power when I turn accessory switch on. So Dad and I built a Y-jumper wire using the rubber boot connectors and jumped off the voltage gauge. I ran the output to the voltage gauge to input of the converter. And the output of the converter to the gauge. The gauge light I changed out to a 24v green led bulb. I then built a 3 way wire and spliced into where the dash bulb gets its power from. This way I can illuminate it when I use the push button light switch so it works like it's stock. I did a 3 way because I wired the Pyro into this setup. Overall I am very pleased with the results. The gauges in the photos appear much brighter than they are. There is a significant difference obviously between the new speedometer and the stock gauges but it gives you an idea. Also, Sgt Tibbs had to help Dad and I throughout the installation. I'll test it out in the next week or so and report back how accurate it is.
