My m925a1 build "Brutus"
muthkw25
710
Canton, PA
Decided to replace the ditch lights with the trucklight floodlights. They added a decent amount of light up high if needed off road. I moved the old ditch lights to corner of the bed near the market lights. This helps with visibility on the sides of the truck. Turned out well. Will need to test at night to see how it looks on the road.
muthkw25
710
Canton, PA
Mounting up a sound bar. Didn't want to drill holes through the fiberglass hardtop. Decided to use a 2x6 wood board. It fits snuggly between the fiberglass reinforcements on back of cab. Used gorilla max constructive adhesive. The board had to be hammered into position. Plan is to drill 2 small self tapping screws through the support into the wood to also help hold and stabilize. I'm going to paint the board marine corps forest green so it blends and then mount the sound bar.
I figured between the adhesive and the screws it should hold very nicely. Then I'll have some tunes in the cab. Ill be painting the 2x6 tomorrow.
muthkw25
710
Canton, PA
Got the sound bar mounted up. Used 2 deck screws with washers on each side through the fiberglass reinforcements. Painted the 2x6 marine corps forest green this morning. Mounted sound bar. The power cable doesn't allow me to have it face directly out where the brackets are so its facing up. Works like a charm. Now I can blare fortunate son while hauling the mail.
