LMTV Air Conditioner AC Main Unit Gen1 and Gen2 Details
GeneralDisorder
4,436
Portland, OR
On the Gen 2 anyway the holes have to be drilled in the cab for the AC fittings. The heater coolant fittings are the same as the non-AC box.
Ned81
183
VA
I figured out that my condenser fan pressure switch on the dryer is bad. If I jump the purple wires together the fans run all the time ( which isn’t the worst thing). I need a new pressure switch but I have to idea how to find the correct one. No numbers on it at all. Does anyone know what will work?
Ned81
183
VA
Is this a factory system such that part numbers will be in the TM?
What is your truck serial number? If it's a TM part I will need the serial number to look it up.
Thanks!
It is a factory red dot gen2
A-t011014edkg
brainsboy
Tampa, FL
Just making conversation but I just added A/C to my LMTV and you can get an evaporator for a BUS off of ebay which has the housing and blower motor, just remove the housing and fan and use the evap/heater core with expansion valve(all one piece) fits directly in the stock location of your LMTV, or least it did on mine which is a 2001. Just cut two holes for the a/c lines and keep the same heat core lines and it all looks original.
Lostchain
526
Portland, OR
Sounds awesome, can you share some pictures?
