- 1,630
- 4,436
- Portland, OR
On the Gen 2 anyway the holes have to be drilled in the cab for the AC fittings. The heater coolant fittings are the same as the non-AC box.
Cool thank you for the tips.On the Gen 2 anyway the holes have to be drilled in the cab for the AC fittings. The heater coolant fittings are the same as the non-AC box.
Thanks!Is this a factory system such that part numbers will be in the TM?
What is your truck serial number? If it's a TM part I will need the serial number to look it up.
Thanks General! I appreciate it!5930-01-573-8366
RD-5-11064-0
I see several on eBay for quite reasonable.
Sounds awesome, can you share some pictures?Just making conversation but I just added A/C to my LMTV and you can get an evaporator for a BUS off of ebay which has the housing and blower motor, just remove the housing and fan and use the evap/heater core with expansion valve(all one piece) fits directly in the stock location of your LMTV, or least it did on mine which is a 2001. Just cut two holes for the a/c lines and keep the same heat core lines and it all looks original.
