Seeking Tech Manual for Nordic Air 18,000 BTUH 3 Phase ECU 567-00001
SCSG-G4
PSVB 3003
5,399
3,490
Lexington, South Carolina
Removed! It clearly reads "FOR OFFICIAL USE ONLY"
That is why we have more than one set of eyes look at things to be posted. Army manuals are easy, they state exactly which letter the Distribution Code is. Other services do not explicitly specify the correct code but use language such as ""Official Use Only" somewhere on the cover OR the first page of the manual, but they are not consistent!
Shiggy0814
St. Louis, MO
I have manuals for the Nordic Air 1.5 ton (18,000 btu), 3 ton (36,000 btu), and 10 ton (120,000 btu). Lots of parts too. I've gotten pretty good at fixing these units and have about 12 of them fully functional with half of them ones I filled r-22 back in because they were drained. Feel free to ask me for help if you're troubleshooting it
Do you still have access to the 3 ton manual? Would you be able to send it to me if you do?
kurt Holzbacher
Florida
Hi. I'm Kurt from Holiday Florida. I bought a Nordic Air 18,000btu 208 volt, 3 PHS, 50/60 HZ. Part # GS1H43ZAANWY001. Serial number GS1H1189. MFGR date 10/08 and it says R22 , 3lbs 2oz... (I'd really love to turn it on to check it out)
Environmental control unit but it is missing the power cord and wires remote cord. I thought I saw on here where a few people were able to wire up their own power cord. If someone could perhaps show me a diagram of drawing of how to wire up a power chord, that would be so very helpful. And if any has a PDF of a repair manual and parts manual please let me know. Says it's tech manual 567-00001. A PDF of that would be helpful...
Also if anyone has a power chord and or a remote control with chord for sale id be interesting if that are reasonably priced. Oh yeah, it's missing the front top right vent cover, if anyone has an extra one they would be willing to let go, please let me know about that too.
I'll attach a picture of the label. And a couple other pictures.I don't know if we're allowed to put our personal email on here or phone number. If so, I'll give it to you. But I'll wait till I'm told by you guys that it's ok to do. Thank you for any help you can give me to get this running.
Guyfang
26,881
Burgkunstadt, Germany
While there are TM's available, they are not coded for public release, and so can not be posted here. There are several threads here in the forum that cover this problem and I believe if you look at them, they explain how to make a cable.
The proper TM number is TM 11080A-O1
kurt Holzbacher
Florida
I bought mine off goveplanet. They sometimes come with the manuals. Unfortunately the one I got was missing the cables and the manual... I tried searching for threads for almost an hour before I posted this. Do you have any suggestions for search words that I should use? I'm apparently using the wrong ones. Or the wrong order... I end up wasting so much time reading through things that don't even come close to what I'm looking for. I guess I'm learning. Lol... Thank you. I will continue to try to search. I just realized you gave me the TM #. Thank you and I appreciate you taking the time to help guide me.
kurt Holzbacher
Florida
Nordic Air was acquired by HDT.
PM me and I think I can get you squared away..
Cheers
Poccur
.... I just got an 18,000btu Nordic Air ECU from govplanet. It didn't come with a power cord or any kind of manual... Its got a built day of 10/08 and R22 in it. Maybe... Id really love to be able to hook it up to power. Do you by any chance have a power cord for it that you'd be willing to part ways with? Or could you possibly instruct me on the correct parts I'd need to make a power cable (parts list, and instructions)?.. again, I'm sorry for the message on the old thread. Thank you for your time.
Kurt H
Hi , do you still have a manual available for the 18,000 Nordic Air ECU? Pdf or hard copy? I bought a unit off govplanet and it didn't come with any kind of power cord or manual or remote. The build date on my unit is 10/08.... If you still have a manual id really appreciate help. Thank you so much for reading this. I'll attach a picture of the label on it.
Thank you,
Kurt Holzbacher
Hello
can you send the NDN in the clear? I can’t read itno matter how much I enlarge your picture.
I’ve got the manual for an 18,000 of some needs a copy?
Hi there, do you still have a manual available for the 18,000? It would be so very helpful. I'll attach a picture of the label on it.
Thank you, Kurt
Did I read that you have power cord for the 18,000? That's the biggest part I need... I guess the remote would be my second wish... Do you have them? And would you reach out to me if you do to see what you'd want for them. Thank you very much, Kurt
kurt Holzbacher
Florida
Hi, Kurt here from Holiday Florida, I'm sorry to bother you all. I saw in another post and I was searching that someone was helping someone with my same issue. (Or close to it). I got a 18,000btu 3ph 50/60hz, 208v takes R22, says tech manual 567-00001, Nordic Air ECU from goveplanet. Unfortunately it didn't come with a power cable or remote cable or manual. i have been trying for months to figure out how to turn it on to test it. I finally found a parallel cable for generators that has the perfect ends. Screws on perfectly and the letters match up... But I saw Suprman wrote in a different post that the parallel cable isn't rated for the voltage of running the ECU unit.... I really could use some help. I have been pouring money out and I don't even know if there is freon in it. And it takes R22, sigh, not the cheapest stuff... Is it possible to take the parallel cable and use the end on it to wire it up with the "proper gauge" wiring, with the circular pin plug (from parallel cable) on the side that screws to the unit and a proper 220v plug on the other, but with new 220v wiring between, So it can run off 220v?
Do you know the actual part number for the proper cable with screw on pin connector on one end and a 220v plug on the other?
Your guidance would be very much appreciated. making the cable would be far better then trying to buy one at this point... I'll attach a few pictures. The parallel cable I bought that screws on perfectly 😔 but apparently isn't rated for it, and a couple pictures of the ECU with tag/label. Thank you, Kurt
TheDrashStash
131
Monroe, GA
Kurt H
Thank you,
Kurt Holzbacher
Thank you, Kurt
Sorry for the late reply. I'll dm you
porscheparts
texas
Resurrecting an older thread here .
I have two of these that I’d like to put to use at temporary climate control in a small residential construction project.
I don’t have any cables, any advice on adapting these to a residential breaker box?
DieselAddict
2,347
Efland, NC
Do you have 3phase power available? If not you'll need to get either a rotary or solid state phase converter to make it work on single phase power.
